Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007!
Go Back   Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Frame/Suspension/Brake... Talk & Q&A All things... Frame/Suspension/Brake
Old 06-14-2017, 04:53 PM
DozerII's Avatar
DozerII DozerII is offline
99% sure the problem is solved, everyone has told me it is the master cyl, after two new ones and still having the same problem I was doubtful. But my experience with brakes was saying the same thing. I was about to pull trigger on a third on and deicided to try the replacement Prop valve that Summit sent me. After the install and carefully bleeding all the air out I went for a test drive and I can't believe the difference in the brakes. I though they were good before despite the problem now they are awesome.
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
