Garage
52 fordman
Jul 28, 2009
349
Hastings , MN
So, life happens and I am thinking about building something like this to use as a garage. I can not use concrete for the floor as it needs to be portable. All wooden construction. No permeant structures allowed as I do not own the property.
Has anyone ever used something like this? There will be no welding or cutting. Just for getting out of the cold weather and simple mechanical work and storage.
Thanks
52 Fordman
A friend of mine has one just like that,it has worked out pretty good for him.Only thing is if I had one I would add a gable vent with a fan,it can get kind of stuffy in there.
Thanks
52 Fordman
I built one for a friend 15 years ago , laid down pressure treated 4X6's 12" on center [ get this part level on SOILD base and the rest well go easy ] then we use a double layer of pressure treated plywood , screwed it all so easy to take apart later , and built it up from there with conventional lumber [ all screwed] still there and solid
Oldog
Portable building
Agree with Odd.
I would design and build it for quick take down. Wall panels bolted together that come apart to load in a truck. Nothing better than taking it with you. Floor panels in 4x8 sheets haul easy. Solid base is the key. Overbuild the floor structure to keep things stable. Avoid screws that strip heads easy.
I'd make sure I sealed the wood floor real good. You don't want the inevitable oil spill or brake fluid leak to soak into the wood.
Shipping container.
These are extremely durable and easy to transport.
20 Footers about $3000. or less
Try that with a wooden structure?
