Old 08-12-2022, 09:41 PM
zzrodder's Avatar
zzrodder zzrodder is offline
Originally Posted by forbigpicture View Post
I'm really diggin' the color too...
I have a question ZZ, you said you prepped to paint...did you use a sealer or some sort of primer prior to paint or just the paint? Inquiring minds want
to know
I just meant cleanup - grinding rough welds, sanding rough edges and all surfaces, general wipe down with wax and grease remover. No primer, keeping it simple. I have to confess to breaking my own rule and using a tiny bit of bondo to fill the gaps between the stitch welds in the door frames and to blend the brass trim to the sheet metal.
That seals the trim to the body skin so water won't get behind and bleed rust down the body sides. Got that done today so final painting tomorrow!!
Old 08-13-2022, 06:48 PM
zzrodder's Avatar
All painted, along with the floor, now a nice brown, hides the dirt....
Started with the cab on its side to spray the underside, then tipped it upright.
As an afterthought, I shot some black semi-gloss between the brass trim to break up all the browness. Inspiration hit me then and I masked off the Flying H and shot it with a Rustoleum gold metallic spray bomb, a fairly good match to the brass trim I figure...
Old 08-14-2022, 07:07 AM
dutch dutch is offline
the black... nailed it
He who dies with the most toys wins
Old 08-14-2022, 08:00 AM
Rockable Rockable is offline
Wow! Looks great!
You Can't Put a Price Tag on a Good Time!
Old 08-14-2022, 08:25 AM
forbigpicture's Avatar
forbigpicture forbigpicture is offline
Please stand by.......
Yeah, baby !!!!!!
Learned a lot from my mistakes....think I'll make a few more....
Old 08-14-2022, 09:16 AM
05snopro440's Avatar
05snopro440 05snopro440 is offline
Wow, that looks so good!
My 455 Buick powered '46 GMC Build Thread
My '46 GMC on Photobucket
When you don't know what you're doing, it's best to do it quickly.
And when I’m gone, you can call me foolish but hopefully not boring. I will have lived.
The more I learn about women, the more I like my car.
Old 08-14-2022, 09:30 AM
smallfoot's Avatar
smallfoot smallfoot is offline
Great eye for detail ZZ!
Old 08-14-2022, 10:20 AM
zzrodder's Avatar
Thanks guys, its really exciting to get it to this stage with the major fab behind me. Now its time to give some love to the dirty old 360 and 4spd. New clutch, etc. for it, then open up the engine for new gaskets, oil pump and general cleanup. Comp Cams keep pushing the ship date farther away for the cam & kit and Edelbrock is dragging their heels on the intake too so I'm just going to put a 4bbl adaptor on to run the 650 carb I have to get it going and work the bugs out, swap the goodies in later - I wanna cruise it!!
Old 08-14-2022, 12:53 PM
I agree that the black is a great touch along with the flying H
Old 08-16-2022, 07:21 PM
zzrodder's Avatar
After scraping, scrubbing and washing of 49 yrs of crud off of the 360, I gave it some paint and bolted on some new parts. Looking much less turd like now.
Putting on shiny engine parts always improves my mood...
Using a GM HEI gets rid of the separate coil and gives a better zap than the old points distributor but having a hard time getting it to engage the hex drive to the oil pump - had the same problem with the HEI on the 302 in the 37 Packard - the oil pump shaft won't stay centered in the hole as you drop the distributor in...
