AB-ie has commenced
Strange willy
Aug 5, 2013
64
Kearney, Nebraska
So I bought a 31' Willys C133 pickup off eBay in April of 2012 with the intent of building a mid-engine rat, the body is real straight with only a few small rust holes, the wood is junk and it was held together with wire when I picked it up out in Parker, Co. There were less than 3000 trucks made in 31' so pictures or parts are extremely hard to find.
So I spent the rest of the year staring at this body stuffed in my garage trying to figure out the design and gather parts, my girlfriends cousin happened to have a mid 80's Jag that I robbed the rear axle out of and a 500 ci/Th400 combo out of a 72 caddy. I chose to go with IFS in the front to match the Jag IRS in the rear but I don't have $4000 to buy the Heidts open wheel kit that I really like the looks of, so with a bunch of emails between a few company's I have enough info to build my own. With the living room in our apt filling with boxes of parts in February I feel I have enough stuff to start.
Lower A-arms 1 1/8" Dom with Chevy ball joint
Upper A-arm 1" Dom with Dodge ball joint
I'm using 69' Camaro drop spindles so I had to ream the upper holes to make the Dodge ball joints fit.
Frame rails are 2x4x3/16, width is 27" wide pinched to 20" at very front to match the grill.
Trying to figure out how much Z to make the frame level, static ride height designed for around 4-5
Since this body was basically in pieces when I bought it and most of the wood is gone or junk trying to find the natural fit of the panels was kind of a chore. This will bite me in the butt later on!
1x1 bent in our 50t press
like
looking great[P
l think these wheels or this style of wheels would finish it off perfect.
(personal choice of wheels:D)
Later :cool:
Thanks for all the compliments, I wasn't sure if my build would be of any interest as there aren't many out there and it is really out of the norm but I wanted something strange and different that could still be long, low, loud, and sinister!
Adding more structure and strength to the body
Have to do something with the doors, wood is old and dry.
Pulled the wood and bent some 1x2 to match the curves
Now I have a door that has a solid frame work and won't twist
I got a good set of stock bottom hinges with the truck but the upper I didn't care for so I found this old set of brass house door hinges and made them fit.
They open and close nicely and the body lines are good
Building the floor with 1x1
Scored some seats from a coworker for helping him remodel his bathroom
