Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Tech Tips!
Tech Tips! Share your kool tech tip.
Old 01-27-2009, 12:30 PM
hillbilly4008's Avatar
hillbilly4008 hillbilly4008 is offline
Default Make your own automatic shifter
This is continued from the "custom shifter knob" thread located in photos section.
lets just pick up where we left off shall we.
I'll get picks and post them later today.
my build pics
Old 01-30-2009, 12:01 PM
sorry it took me so long to get these pics. These are the best pics i could get with out tearing it all down.
ps. maybe someone could post "quotes" on this thread from the "shifter knob" thread. I would, but i dont know how to insert quotes from different threads.
Joe
my build pics
Old 02-10-2009, 03:45 PM
RuninWolfe's Avatar
RuninWolfe RuninWolfe is offline
Now see.. This is why I like this place. There is always a way to get it done without spending a ton of money. The whole thing with hot rods was to fabricate something from nothing. They werent parts installers....
Old 02-10-2009, 07:41 PM
Blue Eyed Devil's Avatar
Blue Eyed Devil Blue Eyed Devil is offline
Devil's Advocate
I really hope you going to incorporate some sort of lock-out into that mechanism. DO NOT rely on the transmission detent to hold it gear! The slightest bump can knock it out, and the cosequences WILL be disastrous. Imagine doing highway speed and jamming your vehicle into park or reverse. It will happen, and it is only a matter of time until it does. Best case - you do serious damage to your driveline/vehicle. Worst case - you kill yourself or someone else. For everyone on the road's sake put a SAFE shifter on that thing...
I'm the dirty dozen for the price of one...
Old 02-10-2009, 08:40 PM
donsrods's Avatar
donsrods donsrods is offline
I had to fab up some sort of shifter for my 39 Dodge truck. It has an Olds 394 and a 59 hydomatic, and no one makes a shifter for that one. I first made one that used a 39 Ford lever, but it was too flimsy, so I remade it using an old Hurst stick I had laying around.
It is utter simplicity and has no detents because the ones in the transmission are very firm. I think it will be ok once it gets welded to the frame and tweaked a little. Here are a couple of shots of it.
Old 02-10-2009, 09:22 PM
Devil's Advocate
Hey Don, I know you are an experienced builder and this is no way a jab at you, or the other fella for that matter. Your setup looks nice, but it still gives me the heebie-jeebies. I had the unfortunate experience of being in a vehicle that had a shifter with no locking detent when it jumped into park at around 50mph. Wound up facing the wrong way in the ditch on the other side of the road. Luckily other than some soiled undergarments we were both ok, but we were just that - lucky! I know of at least two other similar incidents involving people I actually know and sub-par automatic shifter setups. For that reason I am a big stickler on this one. Looks like you could possibly adapt one onto the tailshaft maybe? I am the last one to call in the safety police, but just lookin' out for you fellas!
Old 02-10-2009, 10:55 PM
RuninWolfe's Avatar
Yes Lord... I remember watching a 69 Camaro flip about 9 times at the end of the quarter once when the driver, Johny Ruth, flipped the shifter up into what he thought was nuetral. It wasnt.... Yes to some sort of lock out. This is a great thread
This is from the thread this thread started from. Hillbilly4008 wrote it:
Do you know what a "shift slot" is? I tried my best to find a picture for ya, no luck. They use them on Older automatic John Deere farm tractors, riding lawn mowers, and self propelled snowblowers with automatic transmissions. Its the shifter that some lawn tractors have on the fender. It uses slots to hold the shift lever in gear, to shift through the gears you pull the lever to the side then push forward and back.
You could also check the local u-pull-it yard for cars with floor shifters. I know that '80s automatic trans ams and camaros used slot shifters. Those work off of a button on the shifter knob. Push the button and it releases the lock that sits in a groove between P-R- and the forward gears.
Hope this helps[/QUOTE]
Old 02-10-2009, 11:18 PM
donsrods's Avatar
I know exactly what you are saying, even my Lokar dropped down into 2nd on hard bumps going to Daytona this year. I have to adjust it tighter. But this shifter actually clicks into each gear very solidly, and the handle is short and pretty tight to the mount. I may add a detent button I bought a while back for another project. It is a spring loaded BB affair that I can locate into some drilled depressions in the plate.
However, many years ago I built a Bugeye Sprite with a 289 Ford in it and made a similar shifter for it. Never missed a gear, and the car was pretty violent when my foot was in it. I'll have to see how this one works out and modify it as needed.
Old 02-10-2009, 11:24 PM
RuninWolfe's Avatar
Now I would love to see a ton of pictures and write up about this shifter. I have a Lokar with a 23" shifter arm on it. It looks cool but I have always thought that I might have to pay for the cool go give up the precision..
Pictures...
Old 11-10-2009, 06:00 PM
rusty46 rusty46 is offline
I need to see pics of these please..anybody?
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
