Old 07-10-2007, 10:40 PM
BruceR&C's Avatar
BruceR&C BruceR&C is offline
Cleverly disguised as a responsible adult!
Default Wiring an AD Pickup
This here is a spillover ffrom this thread: http://ratrodsrule.com/forum/showthr...=newpost&t=247 .
Since this is an in depth coverage of wiring Mama's truck, I figured it shoud have it's own space. For wiring the truck I'm using an EZ Wiring 18 circuit harness kit. Before even touching the wiring, me being fanatical about instruction books, spent a few hours going over them & making notes as to where all my accessories fell in on this harness. Since I have some additional accessories that needed wiring of their own, I figured those would be wired before I even touched the truck harness.
Last nite & this evening were dedicated to wiring the radiator fan, speedometer & putting in new oil/temp sending units.
Driving Yesterdays Rides-----Today !
'47 Plymouth Coupe - mine
'47 Chevy PU - wife's wiring
Aerodynamics are for those that can not build engines. - Enzo Ferrari
Old 07-10-2007, 10:42 PM
BruceR&C's Avatar
Finishing up the radiator fan wiring.
Old 07-10-2007, 10:44 PM
BruceR&C's Avatar
Wiring the pulse gen for the speedometer.
Old 07-14-2007, 01:51 AM
BruceR&C's Avatar
Now to prep the harness for installation,,,,,
One nice thing about this harness is that EZ has divided the wiring into 4 basic groups : front, dash, tail & steering column.
Old 07-14-2007, 02:02 AM
BruceR&C's Avatar
Using my trailer as a work bench, I first make sure all the wiring I need is there. Then I seperate out the wires I'm not using as of now. I then further seperated each group into smaller groups.
What I ended up with was:
Dash - gages, headlight switch & misc accessories
Front - lighting & eng accessories
Tail
Steering column - the items that are connected to the column have the
ends on them from the factory
I also made a seperate section in each group for wires that will be used later or maybe not at all.
Old 07-14-2007, 02:03 AM
BruceR&C's Avatar
Finishing the seperation process,,,
Old 07-14-2007, 02:07 AM
BruceR&C's Avatar
Next up for me is setting up my column wiring & wiring the speedometer reset button.
Old 07-14-2007, 02:11 AM
BruceR&C's Avatar
Finishing reset button & mounting on speedometer. Mounting the fuse box mount,,,,,
Next I get to start running wire. It aint gonna be here much longer !
Old 07-15-2007, 12:48 AM
BruceR&C's Avatar
Started out small by replacing the park/turn signal lights on the grille
Mounted the fuse panel. What a mess of wires
First set thru the firewall,,,the front lighting !
Old 07-15-2007, 12:53 AM
BruceR&C's Avatar
Next thru,,, the engine accessories,,,,
Tail-lighting is last to come thru
The mess is clearing up!
