Model A extended cab
exhaust is 100% done!! check it off the list!!!
Looks good LB, never seen or heard of purple horny's before must not be available up here.
really?? they have been around for a long time. they must not let them cross the border hahahaha
thanks pops!!! I'll keep truckin on it!!
A long time indeed.
I had them on my 55 Chevy back in the 70's. They were the big "alternative" to Cherry bombs. I also had the "Heavy Breathers" headers on that car as well. All made by Cyclone back then. They were another option vs using the "Hooker" headers that were the thing back then as well. As I recall they also had really cool stickers that we would put on our rear quarter windows.:cool: :cool:
Always tried to be a little different.:eek: :D
90 degree master cylinder Mount has been butchered and put back together to make fit. Brake booster and master cylinder are mounted. Gas pedal and brake pedal are also welded up. My structure to mount the steering column and the master cylinder is all welded. Might add a couple more braces. I built it so I can cheat the bottom of it and make it look like the factory gas tank
Looks great [cl
Will there be a panel so you can check the fluid ever now and then?
[P[P[P
you can reach up from the bottom and pop the cap then unscrew the original gas cap and the master cylinder is right below it. all my A builds have been this way
