TubularFab
Active member
Ok, I bent some tubing, welded, and cut on the firewall, so I guess I have officially started on my build. I will make no claims about the rate of work on this project - I hope it goes quickly, but if I get too busy this is the first thing that will suffer.
So, I picked up a very rusty set of 1940's International KS-5 sheet metal about 6 years ago:
I picked it up with the intent of building a rat rod, and figured it was in good enough shape to be perfect for that. My initial plan was to work the front sheet metal into a COE type nose and place the engine in the back. I was going to trim the bottom off the cab rather than do a chop (at least the internationals have a pretty low window stock!) and use the nose for legroom. However, now I have changed my mind on this for 2 reasons. First, I would be losing out on one of the coolest parts of a rod - being able to see the engine while driving. Second - the overall length of the truck was going to be longer than I wanted in order to get all the driveline in with a mid-engine design. So, I am now switching to a more conventional layout with the engine in the front.
Another major design element for this build is the seating requirement. I need to be able to seat 2 adults and 3 kids. I have 3 boys - 10, 8, and 6. My last project car was a 2 seat sports car, and every time I drove it we had battles over who got to ride in it first. It was impossible to go as a family to any kind of car show, etc without 2 vehicles. So, this build needs to haul the family. I've looked at old truck cabs stretched into a crew cab, but don't really care for the look. So I am going to try a different approach. I am going to cut the entire back out of my cab and fabricate a 68" wide, 36" long sleeper to connect to it. It will look like a period correct sleeper off a tractor trailer (though with more windows) complete with rounded corners. This will have a bench seat in it for the boys.
To mock the sleeper up I bent some 1" tubing and tacked it together in the planned dimensions. Here are pictures of the mocked-up layout:
From those pictures you might have noticed some of the other plans. I want to go dually with rather tall tires. I'm going to look into something like old style 20" truck tires, but for now will be going with typical heavy duty pickup 235-85-16" as I have a spare set of wheels and several old take-offs to play with. I have a low mileage 3.55 rear end out of a '91 F250 diesel that will be used. Since it was not a dually rear it is actually shorter, and should work well even with duals on it - and not be crazy wide.
I'm planning to keep the front end very short rather than doing the typical stretch. I just prefer the look - will probably be pushing the front axle centerline back and let the engine stick out in front. This will help give it a nice turning radius - which is important since I plan to drive it to work in the city.
![IMG_1066.jpg](https://proxy.imagearchive.com/db4/db410330d70a12ccc44b28815048698f.jpg)
![image1.jpeg](https://proxy.imagearchive.com/33f/33fb18f9b68405ef3fd864a2693d2113.jpeg)
![image2.jpeg](https://proxy.imagearchive.com/3e7/3e7d78b59df4061c375c83704e5e64b1.jpeg)
![image3.jpeg](https://proxy.imagearchive.com/526/526fb6d9b9c28e450d2e61047a9af685.jpeg)
![image4.jpeg](https://proxy.imagearchive.com/2e7/2e71c758633e15c5c82b37d4e9eebb65.jpeg)
![image5.jpeg](https://proxy.imagearchive.com/a43/a4361cf8b66473dce4225d6aa85f86d1.jpeg)
