Coil suggestions
DozerII
Sep 4, 2015
4,775
Saskatchewan Can.
I running the stock electronic Dodge distributor on the 440, instead of using the crappy Dodge lean burn electronic ignition, I'm using an Accel GM electronic module. I'm having trouble finding out what coil I should run with it, any suggestions?
GM's HEI coil spec is 0.5 ohms primary resistance. Anything higher will limit voltage output. Stick with .5 and you'll be good!
