Well it's starting
Daman
Aug 28, 2009
288
Now the fun starts. A little cuttin and a little weldin and it should sit around 11"-13" lower.
Olds Frame
Parts truck
This frame is gonna be cut up and put in between the Olds frame then the outer frame is gonna be cut off
Man that sheetmetal looks to be in great shape. So pretty much you're just planing on subbing the old frame? Keep us posted on progress.
Just getting everything even before starting the frame. I know it sounds backwards but that's how I'm working LMAO
And it will sit down quite a few more inches when the frame is finished
Got the donor frame cut out today and will start measuring to weld it in
I sure do like the looks of an old IH truck. Yours has kind of a Rasta feel to it with those cool colors. Looks like you are making progess with it already. Still having a hard time believing you cut the old body off with a pair of bolt cutters.
i like where you started.....i like where you're going......and i sure want to see ya get there!!:D:D
i like the looks of the old binders, too, and i think you'll have a cool old truck that is also easy to drive&enjoy..:cool:
HRP
Got a little bit more done today.
I had to move it outside. Them old timers keep it so hot in there and they were complaining about me and my speedo.
I thought it was close to being on before I used the rods to shore it up. Now there is no doubt
Man, that IH is in great shape! Keep it coming. I like it. I'm interested in the project, want to see how you accomplish the cut-n-weld. Perley
Man, that's crazy! Great idea for frame alignment, who woulda thunk!?!;)
Can't wait to see it without the bumpouts on the sides of the frame. 'Course, you coulda just left 'em on and used 'em to bolt down your running boards!:rolleyes:
I vote to keep the turbine wheels, too. They's much cool.:cool:
Oh yeah, MORE PICS!!!:D
Regards,
Shea:)
Here it is mock up
What I didn't get pics of was the plumb bobs, levels, straight edges hanging everywhere. I've never done anything like this before, so I figured my plan yesterday and set out to accomplish it today. Everything is now tacked in place and just a few more brackets for strength need to be made before the final weld
I cut holes in the Olds frame front and back to add tubing. It will be welded inside after the Olds frame is cut off. These will be boxed in for more strength. The front is at the top of the frame and the back is more towards the center for torsional twisting
Front
This is also going in behind the boxing of the frame for more strength. There will be 2 each side front and 2 each side back.
This is a front one that has to be notched and another will go directly beside it to completely cover the bar going through the frames They would make a W if looking at them from the top. Ya never know if a special Big Block is going in
I haven't welded anything heavy duty in some time so some of them don't look Too hot and it isn't final weld so please be gentle
Beer can and a half high. I think it's gonna sit pretty nice
rear taped and painted
front taped and painted
