Fox Fabrication
Here I go again!!!!
I've always wanted to do a 1960's drag truck style vehicle...but could never find the right cab for the right price....I ended up driving 3 hours to south Jersey over this past weekend to see what I got myself into....
Burried in the woods was a 1937 Chevy truck...With the help of an excavator....it was pulled out into an open area, torched free of its worn out frame and hoisted into the back of my truck.
The bottom 3" of the cab is gone to the rust gods...but above that is still very workable steel. The roof is mint...no dings, dents or anything else...the window frame has a little bit of rust-thru...but the welder will take care of that!!
I also was able to get (at the same location)....a near perfect bed for the truck, workable rear fenders (if I even use them--most likely not) and a very good condition grill shell.
$200 loaded into my truck I couldn't refuse it.
If I can find lower patch panels I'll fix the bottom...if not..may plasma off the bottom 3" and go frome there.
Plans are to build a 2x3 frame with full roll cage (6 or 8 point)
4 link coilover rear suspension
Blown BBC
Powerglide with brake
Ford 9"
Straight axle
Fenderless
aprox 115" Wheel base (may change that a bit-undecided right now)
Tons of stuff to plan out...but keep posted...Will be updating as it progresses!
Sorry for the poor picture qualty (crappy camera phone)
Blown BBC
Ford 9"
Straight axle
Fenderless
