1952 Dodge pick up rat-resto
rattman 68
Active member
Oct 19, 2014
35
Brewerton NY a suburb of syracuse
Hey This is a project I've taken on to resto this truck for a colleagues soon to be 18yr old son. Pretty nice 1st vehicle if you ask me. (luck little runt)
Its a 52 dodge pick up on a 75 ram charger frame 318 2 bbl auto trans...
Im lowering it 6 inches cutting out the completely rotted cab floor finding and installing a bench seat.
So far i've taken out 2 helper springs off the front suspension, cut out half the floor and made the distributor accessible by cutting away more of the fire wall.
thought
nice[cl
on mine we used a wheelbarrow cut down for the dog house, worked good and looks pretty decent when it was finished.
Later:cool:
a wheel barrow is an interesting way to build a trans hump. Hmmmm i'll consider it. I was planning to use 16 gauge diamond plate steel ( extruded steel is $$$) and i've built an extruder but takes too much time. I also have to devise a removal access panel for the distributor. In the past i've used a 55 and 25 gallon drum cut in less than half then in a triangular down the side for the trans hump.
pics, get yer pics here
here are a few pics.
we built a flat area for the fuel pedal, the way we did the interior still leaves a lot of leg room.
Later :cool:
update
Only had an hour to work on the project after work today. patched the trans bell housing. ( was rubbed through from rotted floor.) Cut out the rest of the floor. The steel should be here 2maro.
update
sorry i haven't posted in a while but snow has been falling Finished the throttle and brake pedal and lowered the front end too.
will post B4 and afters.
Nice work. I like the access door for the distributor. Of course it would have been a lot easier if it was on the right end of the engine to start with. :D
Ahhh you mean like a Buick engine.... Right.
Just F-ing with you blue oval man, if it was made in the U.S.A. its all good.. as far as i'm concerned. ( exceptions are Ferrari, Bugatti and Ariel Atom.):D
