assembling a 30-31 roadster project
You never disappoint.....
Those door panels are killer....I'm not a big peckerhead fan but looks great on the door panel....nice..[cl
making some progress on this one.
frenched in some 59 caddy lights, the old tail light holes
the new going in
welded some supports in on the back of the tail light can
all welded up and ground down
made some brackets to hold the fuel cell
welded up and smoothed out the gas tank/ cowl side seam
working on setting up the steering, got to love string
Looks good as usual. [P
Side note: You may want to step up to DOM string. That yellow stuff is only ELW (electrically wound) and won't hold up to the abuse. :D
started making the new hood sides
it is two separate panels so it doesnt have a big hole under the headers
think i might remake the filler panel under the header, the louvers look funny
and drilled all the mounting holes for the dash panel, and got the gauge pod mounted
i got to make some more progress on this one last week since i had a car not show up. hoping to get this one ready for the owner to finish up this week.he wants to do all the plumbing and wiring on it. any way i got the steering all mocked up, the hood latching, lower windshield stantions re worked and fitting good, and the front shock/ head light mounts cut down and tacked up
front hood latch
rear hood latch, i put this one upside down since there is not a lot of room between the hood side and the header
handles
this piece is welded to the hood side and slides behind the lower section of the hood side ( the part that stays stationary on the frame) to hold the two pieces together when the hood is down
the spreader bar cut down and fit up
getting the steering all mocked up
the lower stantions fit up, this was a lot more work than it looks like. took about an hour of massaging each to get them to fit right
Very nice.....
Attention to detail is really your thing and the builds are killer....what can anyone say.....you have the gift....
Excellent work per the usual... I like the door panels... My dad wants me to put some of those old bird stickers on my truck... I told him no way I'm putting any stickers on it... I guess u fixed the whole sticker thing
