Best rust removal
imthegrt1
Oct 9, 2013
68
Kentucky Meade county
So is the molasses the best the best trick and easiest and cheapest way to remove rust.
Depends on the size of the parts. I'm using muratic acid and loving it. Really cleans, and in a short time. Every body says use it 40-1. I am using it straight. Works for me.
Good and bad points like most things.
Good is: Relativly Cheap. Works. Friendly to the environment.
Bad is: Stinky. Messy. Attracts critters and Bees. And if your not careful it will pit the metal. Plus you really need something big enough to submerge the entire part in.
Torchie.
I like electrolysis because it doesn't eat away more metal and is nearly free. But, like several rust removers that need to be rinsed, it has water involved and that causes light surface rust.
