440Clark
Just in the planning stage right now so before I reinvent the wheel anybody out there built a tunnel ram for a 302 Ford before? Or anything for that matter? Let's see some pics.
I was thinking of using a bare block and heads I have laying around to mock everything up on. I'd use something like 1/4" plate for the 3 piece bottom ( a large plate to seal the valley and two sides kind of like header flanges) and weld them together while cinched down to the motor. I was thinking of just using exhaust tubing for the runners. Let them be round where they enter the plenum and I'll fit them to the flanges just like building headers. Then I'll build a sheet metal box with a V bottom. It will be set up for one carb. I still have not figured out the plumbing for the coolant yet but I'm just thinking out loud right now.
I know a tunnel ram isn't necessarily the hot set up and we could go on and on about plenum volume, runner length, cross sectional area, Helmholtz waves and blah, blah, blah-BUT the coolness factor is what I am ultimately after!
I was thinking of using steel because I'm just not there yet with the TIG welder however I have a friend who would probably do it for me in aluminum. If I make it out of steel I'm afraid it's gonna weigh a ton, although I had a cast iron six pack intake once that I guarantee weighed more!
What do you guys think?
