neverwintercycles
- Joined
- Sep 13, 2008
- Messages
- 12
so i spent a considerable amount of time surfing the web yesterday for knowledge regarding installing the camaro rear end i picked up
i'd like to re-use the leaf springs from the 53 dodge pickup suspension if poss in order to save cash.
the camaro axle is wider than the dodge but i am not running fenders so i dont think that matters.
here's what i get confused on:
- i want to lower the truck. what is the correct sequence to install the suspension while taking this into consideration? do i install the wheels etc and then the suspension and then work on lowering it? obv the wheel is not going to change so i would thik i need to have that in place - or at least the measurement for it - to do this?
- my plan is to channel the body. i have beenn told the best option for lowering the truck frame is to z the frame. but others c-notch it, others use dropped spindles, others flip the leafs upside down, some use a dropped axle -
HOW THE HELL DO YOU KNOW WHICH METHOD TO USE? LOL
i just need help with the plan of it all so i can research the actual building of it
