Dagels 29 model
gasser
Oct 15, 2010
118
5025 Sherwood Dr Fort Worth 76114
Well its taken awhile to find a good 2 dr sdn since the 39 Plymouth pu sold but I have finely found one in Wisconsin.
The body has no rust through and the price $3000 ant to bad for what I am getting, Will be heading up Tuesday the 23 July 2013 to pick it up 900 miles but going to see relatives in Minnesota any way so shipping will be free more or less.
Wont get to start till this fall have a 53 ford custom line and a 58 Edsel to finish first. But will start gathering parts for the build
any one got a f-1 axle between Texas and Minnesota
Well picked up a 331 Hemi kit $2700
Here is what I got
Most part were bought through Hot Heads
A short bell housing 331 Industrial engine ser # IND-24-21883. The block had $856.69 worth of work done: magna fluxed, lined honed mains, square decked the block then bored 0.030 over tanked and cam bearings installed. Was in a 54 Chrysler
Crankshaft # 1409421 was Maga fluxed oil hole chamfered and polished
Pistons are Ross Pistons JC129285 10.0 to 1 bore 3.843 dome height .332 net dome .36
Rods # 132422/308DF47 were resized and new bushing installed They reused old rod bolt I will install new ARP bolts (should not throw the balance off)
The bottom end was balanced
The heads are #14868331 they were magna fluxed new hard seats installed valve job done 2 valves were replaced I will do a mild port job, port match the heads install new stainless valves and do a 3 angel valve job.
Rocker arm shafts rebuilt New Rockers and Shafts
Rings are Grant C2339.30
Main bearing from King MB5217AM /916M std
Rod bearings brand unknown MOR354 std
Cam kit is a Iskenderian 300171 Hyd. complete Cam, Springs, Keepers, lifters 270 Megacam
Set of adjustable push rods # 21053.5
Hot Head timing cover set up for Chevy. water pump
Timing chain and gears are Melling Select roller #40202
new balancer 3 TF-07-08
Weiand aluminum water pump
Billet crank and water pump pulley
Billet alt bracket
High volume dodge 340 oil pump and screen with Hot Heads oil pump adapter
Hot heads oil filter adapter
Hot Head oil bypass piston
Hot Head dip stick
Taylor plug wires #75089
Hot Head 727 Torquflight Transmission adapter ,flywheel, and gear reduction starter.
MSD Distributor # MSD8381 and blaster 2 coil MSD8203
Hot Heads 4 barrel Aluminum intake manifold
Holley 4160C (600CFM) will replace with 750 or log type setup
A set of block huger headers
Stainless steal bolt kit
Edelbrock 14"air filter #BK7353554
Parts I need to buy
Head bolt or stud kit
Main bolt or stud kit
Rod bolts
16 stainless valves
master gasket kit
Oil pan
Cam thrust plate and bolts
so should have a properly rebuilt Hemi for under $4000.
this frame was pickup up from TheTruant along with a RPU starter kit not sure which one will be built first the SDN is (cant believe I am going to say this) to nice to turn in to a Rat Rod even though that is or was the plan
at this point I have 2 piles of parts
the 29 RPU and the 29 SDN
a 331 Hemi and a 350 Chevy
a nice frame and 2 sticks or 2x4 x1/4 tubing
2 new 4"drop axel kits one with 4 link and one with split bones
2 9"rear ends
set of rear ladder bars and a 4 link rear kit
1 title for a 29 pu working on the SDN title
Very cool, cant wait to see more progress on this. Looks like you lots of parts and a good plan to building something pretty bad ass.
-Chris
