CR55
It's just a little surface rust!
94 chevy pickup with no brakelites!!! Changed brakelight switch and bulbs, still no lights. Any ideas? Getting kinda scary out there. I need the truck desperately for work.....thanks
Turn signal switch in column probably, the brake light run thru that.
much like the previous post, my 03dodge p/u had one filament of a bulb go out and all of the lights in the rear went out. I chased for over an hour, got ticked off and put new bulbs in all of them and it worked. I checked the bulbs later and found the culprit. my $.02.
Grounds are also a huge source of electrical problems.
Did they ever work, do the blinkers work, do the running lights work?!
Sorry SgtPontiac. We were both typing at the same time....didn't see your post.
Lynn
A couple things if the above checks out and you're still stuck.
- If memory serves me, those Chevy trucks have a ground wire on the frame at the rear driver's side. (Comes out of the harness for the lights).
- If you have one of these crappy inline trailer wiring adapters, pull it and wing it over the fence. I've chased lighting issues for hours and found them to be the problem.
