Doors apart.?
BadRATT
Nov 15, 2008
347
Michigan
Ok..I just picked up a better cab to start yet ANOTHER build...LOL..and I need to know how and the hell do you get the doors handles & door opener off.? I tried looking behind them but nuttin...This is a 1948 F1.The chrome around the handles seems to be spring loaded if that helps..
Push back the spring-loaded center piece of the trim ring. You will see a pin that holds the handle on. Pull or drive the pin out and it will release the handle. All early Fords are built this way...
Tripper...LOL
I know...I shouldnt have bought this last one but it was too damn solid to pass up.All of the inside is there,even the heater..!! It only has one bad cab corner.I looked inside the door and it looks like its been rustproofed..:confused: Does need one rocker panel re-placed but I ready.!!
Worked perfect..!
Just like it says.."It worked perfect." Got the handles off ,glass out..Thanks B E D .!!
