Engine block ID help
RatTrap
Active member
May 20, 2011
44
Huntsville AL
Can someone explain what the numbers stamped on my engine block indicate?
The guy who built my rod died last year and it would be a lot easier
to get parts if I knew exactly what I was driving.
It is a Chevy 250ci straight 6
Stamped on the right side:
CON2 F129 3921968/GM/62
Thanks for the help
Engine ID
Rat Trap -- From the block identification section of Leo Santucci Power Manual it show's the following:
1966-70 230" Chevy Pass Cars
1962-79 250" Chevy & GMC Trucks
I believe the F129 is date code June 12 1969 or 1979
Both the 230 & 250 have same std. bore of 3.875", but the 230 has a 3.250"
crank & 250 has a 3.530 crank.
Do you know for sure that it is a 250" motor?
The other problem with the 194/230/250 is the heads interchange and you may have 250 head on a 230 block or the other way around.
