vintagered13
Figured I would try over here with this question.
I'm building a 327 from a stripped down block. This will be my first engine build so all help is appreciated. Right now I have:
• Camel Back Cylinder Heads bare #3782461 dates F125 and F135
• 327 Block and Crank - Cylinders .30 over and Crank .20 Under
• 3" Ram Horn Exhaust Manifold
• 2101 Edelbrock Performer Manifold
Now I'm searching around for a good set of Connecting rods, and I came across some terms that you guys could help me with. The term: "Full float" rods as compared to "Semi float". If anyone can define what they are and which would make for a better build I would appreciate it.
Thanks again
V13
Thanks again
V13
