sgo70
I'm just thinking about putting my engine onto my frame today and I can't decide if using my engine lift plate is a good idea. I got one of these:
http://www.speedwaymotors.com/p/2923,122_Engine-Lift-Plates.html
I have the aluminum AFR heads with an aluminum Edelbrock Air-Gap intake on it and the carb mount studs are about 1/4". I don't really feel good about putting all that weight onto those little studs bolted into aluminum. I guess I could put eight little bolts in as it has both Edelbrock and Holley stud holes.
The alternative is two steel engine hoist loops that will bolt in using the intake bolts but then there is only two and they're into the aluminum heads.
What do you guys think is the best, I don't want to drop this thing.
Sean
Sean
