I picked up a 1987 302 ford engine with supposedly 25-30 thousand miles which an older gentleman had in his 56 ford show truck (very nice truck!) he had a muscle motor built for his truck and no longer needed the old 302. I stripped the motor down to a short block and added my own stuff. I put on set of match ported and slightly polished heads from my old motor which I had rebuilt prior to putting on the new motor, aluminum intake, holly 600 cfm carb, new isky cam and lifters, new double roller gears and chain, new 50 oz harmonic dampner, new 50 oz flywheel with new pressure plate, clutch, throwout bearing and shop rebuilt T-5 trans and my HEI distributor from my old motor with new cap, plugs and plug wires. I finally got it all assembled and stuffed in my 62 falcon but after getting it to fire up it has a bad vibration that gets worse with more RPM. When I previously had the motor down to a short block it was on an engine stand and I was able to spin the rotating assembly and move the pistons up and down with no problems and everything looked good. I haven't been able to run it long enough to break in the cam and don't know what I possibly missed. There are no rattles or thumps coming from the motor. Any suggestions
