Last couple days i had to rework my brake pedal and my gas pedal. Check out the pics. The brake pedal was about 17 inches off of the floor. I took the pedal out, cut it at the first curve up from the actual pedal. I took some 1/4 inch plate metal, and cut 2 pieces out. I then v butted the 1/4 inch steel to the original pedal and welded it up solid. The pedal is now 5 inches off of the floor. As far as the gas pedal, well it was actually 1 bolted against the firewall. I removed it, took a piece of 1x2 tubing, cut it to the length i needed, drilled 2 holes in it for the pedal bolts. Welded the 1x2 to the firewall and set the 5 inches off of the floor and 5 inches center of the brake pedal to the gas pedal.....Sitting in the truck, it feels natural.
