Z.Z.Rat
Monday a.m. went to Indy & had both elbows worked on.Thought I'd pass along the type of surgery so if any others are headed down this road.
Commonly known as tennis elbow. For a little over two yrs it has been getting worse to the point can't hardly work any longer. The routine procedure filets you at the elbow & scrapes scare tissue out, sews you back up & 12 weeks later you can start work again.
New technology uses a small incision & orthoscopic tool that pulverizes the scar tissue. Six weeks lifting 5# & working your way back.
Now I get to spend a lot of time on RRR!!!
Will let you know how the outcome works.
