bullet
A major problem to overcome in chopping the Studebaker roof is the curved rear glass. The rear glass is tempered, it cannot be cut, therefore the rear window opening has to remain stock size. ( you'll find the rear window proportions will be better at the end result ) To accomplish the task of chopping the roof, the rear window frame will be cut from the roof and body along the drawn yellow line. Spot welds inside the rain gutters of the trunk opening will need to be drilled first and popped before cutting window frame loose.
Frame removed.
This is a 3" chop, so 6 inches was measured up from the bottom of the windshield posts and marked. A mark then was measured 3 inches below the 6" line and tape filled between the 2 lines. There should be 3 inches of untaped post still remaining below that. The door posts and quarter window posts were measured 3 inches up from the body line and marked, fill between the 3" line to the body with tape. All the posts were then cut along the top edge of the tape and the roof was freed. Once the roof was removed, 3" of remaining tape or pillars can now be removed by cutting below the taped areas.
Frame removed.
