RUSTY50F1
@$$Fault Junkie
This maybe a DUMB question; But here goes. If you don't ask you'll never be sure. As you all know I have a Jag IRS under my 50f1. What I need to know is If the center pumpkin is mounted to a cross member that is welded to the frame on both sides (which makes it stable) do I have to use a soft hose on the brakes or can I run hard line all the way to the Disc brakes?
