willy knight
Active member
I have found that when I use the old wiring in my cars sometimes the head lights or tail lights are dimm from not making good contact.I have found that putting a dab of the silver Anti -Sieze on the head light prongs and then putting the plug off and on a few times to smear it in the socket works excellent.I live in a salt state and the bulbs sieze in the socket some times.This works on tail light bulbs also. Just put a dot on each of the contact bumps on the bottom of the 1157 bulb and put some around the outside of the base.Do not smear them together for this does conduct electricity.This works perfect so you can drive your old wireing until you can get new.I also anti-sieze where the grounds bolt to the body.
