V8Square
I have, what many of you may think, a stupid question. On my build, I am using a sbc 350. Question on the motor mounts. Are they both at the same height on the block and the same distance back from the front of the engine? Water pump. Is the water pump hub/shaft in the center of the engine? I know these may sound like stupid questions, but I had to ask anyway.
One last thing. If I have may chassis level, at the ride height I want and set my engine in place, with putting a level on the carb mounting base of the intake, if the level shows level, should that give me the proper engine tilt, front to rear?
Thanks for help
Thanks for help
