motor size queston
jensens ratrods
Apr 30, 2010
90
necedah wis
just got a 307 out of a 1986 chevy caprice wagon . freind of mine got the car to demo so pulled out motor to put his in. runs good but the motor looks bigger then a 307 how can i find out what size it is have picks
That looks like an Olds motor to me. If so behind the water pump is where the number is located, if the last one is a letter you have a big block or a small block is a number. Olds FAQ has lots of info if is an Olds motor
307 olds motor
i looked at the numbers and i google it lots of info on there . it is a small block small block measure 12 inches across and big block is 14 inches across the manifold to heads thanks for the info nice to go to a site have people help you out .great place thanks again
That is NOT a SBC 307. It looks like an olds motor and could be anything from a 260 to a 403. GM used whatever they had laying around in the 80's just to use up left over motors.
