I took a piece of 5" exhaust pipe and cut it to 12 inches, took cardboard and built an intake template and built it around a 6" filter. Do to the difference in size between my carb throat and the pipe, i split the pipe down the center and welded in a new piece of metal so i could hit my 5 1/8 inch carb opening.
In the first pics you can see the prefitment. I took it back apart and then cut the pipe to 6 1/4", that way once i build the intake you should be able to see it from the inside of the cab......Hopefully i'll catch allot of fly's.
I also tossed in a picture of the floor plate i built to go around the opening in my floor pan.
