My Build
DougnDog
Dec 10, 2007
481
Sacramento CA
Hi Guy's well I'am behind in my time frame, had the flu:mad: but here go's if you can stand my spelling I'll try and tell you what I'am doing here. first couple of pic's are of my daly driver and the love of my life:) her name is Sweetpea. on to my build, started out a 46 Ford cab I chopped the windsheld 4 inches and in the process of building a removeable hard top. the engine is a 250 Chevy six I'll be running 3 carb's, HEI, headers. all my fastners are stainless steel ( habit from liveing by the ocean most my life);)
The next pic's are cutting it up and filling in the windsheld and back secition the doors are closed at the top no windows I filled the tire cutout and will expand the foot room inside by opening the stock wheel cutout on the inside give's me a extra 4 inches inside.:)
the next bunch show the cab pretty much done with the heavy work. the mock up of my roof lines are in place as is the windwings I intend to build. the roof lines took a lot of beer and sitting on my crate, my neigbors would walk by and ask if I was ok because I would be their so long. :eek: but I finly found the lines I was looking for:D the last pic is my engine the Alum. is olny wire brushed don't need shiney.:rolleyes:
The next work that was done, was to mock up my cab and engine once ALL measurments were figured out my frame was ready to build. I cut all pieces to size, not wanting to build a jig I laid one side on the floor and shimed it level ( 6 ft stright edge), tacked it narrow edges only 4pcl's each joint then laid the other side on top clamped them toghter and tacked it as well. then I welded out the long side of the joints. going side for side to prevent the welds from pulling.next I placed my mat. for my cross member ( 1x1x1/8 wall ) on my table and shimed each piece level ,screwed them to the table. ran a center line square with the 1x1 tube next I alined my 2 frame rails to the center line and squared them to my 1x1 in a up right plane. tacked it down. the frame rails are wider in the back . then I installed the end's the frame came out square and true:D the last picture show's all the tools I used,nothing fancy:). the cost $180. for the 2x3x3/16 x30ft tube,$26. for the 1x1x1/8x20ft tube pretty happy with that cost:)
Next was to set up my engine in my frame, and check out the cab position, building my moter mounts and my cross member
the build goes on:D got my wheels last week so as soon as my cab comes back from the sandblaster ( been raining here for 2 weeks) this week I hope, I can build its mounts. as it sit's it was to be 6" off the ground but I think I'll drop the whole thing 2" more:D I'am at the point I need to deside how low to go. I'll have my front spring built for me this week as I'll will be building the rear 4 bar set up. that's it for now I will post as do more work . I plan to have it up and running in April:rolleyes: I hope! as I will be selling my 47 truck and trailer in the near future Doug
You've got a lot done already DougnDog. What is your roof going to be made of?
It's going to be sheetmetal covered with canvis I think they call it a carson top :confused: I know the look I want, flat black canvis with a little give to it when you touch it Doug
Doug the lines are perfect. what are you going to do for a roof? cloth? it looks great.
Pablo
Hi Pabio first I'ed like to say your drawings are are realy GOOD:D:D the top is going to be sheetmetal with a canvis covering I think it's called a Carson top. it will unlach and be lifted off when you want to run open.
Doug
Did you get your cab blasted?
Yes I did on friday it turned out good.:) I'am mounting the rear end this week and finshing up the front wish bones as I got the front spring on monday. I'll post progress pic's this comming weekend. unfourtunely I'am cripled up, my legs most'ly so I only have enought energy to be on my feet for 4-5 hrs a day. so my progress at times is slow. I'll post soon:D
Doug
Help with the WIFE,,,
Could you post some closer photos of your chop and how you went about making it look nice? Like your door tops, Windshild top and back cab. I'm trying to convince my wife that this would be COOL. I think it is,,, She's one of them girls that needs a pitcher drawn up for her. She can't see it.:confused:
Sure thing man I took a lot of pic's of it in progress. I'll be glad to plot it out as I spent a lot of time on the milk box thinking about it lot of beer too. this is a hard size cab to get to look good. I'am giveing it a try:) first pic cut along the belt line about 6" above the windsheld is choped 4". it has a 2" strap of 1/4" with nut's welded on inside the windsheld post for the windwing to fasten to. on the top section ( inside face ) are straps with nut's welded for the holdown brackets.
Around the back I used some of the reinforceing chanel that came with the cab, just cut and bent to follow the line I setup. I put 1/4" x 2" straps about 30" apart. they will have locating holes for my top ( top will have pin's in it ) so it will have a positive spot to sit each time. the pic's of the door tops (sorry dont know how to turn around) I just followed the lines that I set up with the back. I left the littel hand grabs on the door top. hard to see:( the windwing was a must it will be a piece of 1/4" with 2 holes for the bracket. it will be able to adjust fwd and back. the mock up of the top is just to see the shape, to build it I'll use 1/8" flat strap formed and shaped to match,clamped to the front and back and fab it in place I will use parts from the top I cut off and fab the rest. I forgot on the windsheld top I left my cut line about 1/4" long and with plyers I bent the extra over to a 90* deg had to slice it in a few places to lay flat. that gives a backing for the sheetmetal cover you weld on. hope that makes since.
last pic for to day the the body is done with the heavy work I'll post this weekend pic with it all togather. Doug
