mystery tierod
Jimmy Wallbanger
Dec 3, 2010
323
Arkansas
found this tie rod when cleaning up some tornado damage around the shop. it has two different ends one with a cast in clamp and on end has a normal seperat clamp. I have it at about 49inches right now with barely over an inch of threads in. the end a 1/2 x 20 threads considered replacing the ends if you guys can id it
All guess here, but a solid tie rod with female thread tie rod ends is pretty uncommon. If you find new tie rod ends they could be quite expensive. You might be better off getting a whole new tie rod and ends from Speedway or RPM.
haha mock up rod. any tie rods for sale?
well too bad cause it looks pretty great up there but i guess ill just keep looking for some ends until i find or make another rod. my front end was out of a 50s ford so i was told so if any of you guys have a 49 1/8 hole to hole if i remember right. id rather have an oe on the cheap but Ill keep rpm on in mind I like his work
