racer135
Was removing the thermostat housing from the cylinder head (A12 engine) of my girlfriend's 1978 Datsun 120y and broke one of the bolts off (upper right one) in the alloy head.
Had about 1/4 inch of the bolt sticking out of the bolt hole. Tried to undo it with a pipe wrench (Stillson type) and all it did was strip the threads off and blunt the teeth of the wrench.
Drilled a hole in the bolt (think its a grade 7) and tried an Easy-out (LH threaded type) and stripped the threads off the easy-out and tapered the hole.
Tried the tapered-square type Easy-out, all that did was turn it into a round not-so-easy-out.
Made my own easy-out by bench grinding an old broken Ramset masonry drill bit shank into a square-taper Easy-out. Hit it into the hole in the bolt and broke off the 1/4 inch of bolt sticking out of the bolt hole so now it's level with the head surface.
The hole I drilled in the bolt was off-centre to make things just so much more easy for me hahahahahahaAAAAHAHAHA!!!!!!! (Yep, I've officially fallen over the fence that separates sanity from insanity, into the insanity side!)
I would try somehow to weld a nut onto the piece of bolt in the head, but every time I've tried that welding/nut technique on a broken bolt, the nut always breaks off and makes it harder to extract that last piece of bolt left in the hole.
I'm too hobo to afford a tungsten porting burr for my die grinder, and don't have the time/patience to grind out the bolt to it's threads (what's the easiest way to get those threads out if I end up doing it this way?)
Could try (dangerously) heating the alloy with an oxy acetylene torch to expand the hole, but I think the alloy would heat up slower than the bolt.
Any ideas folks?
Any ideas folks?
