skull
''SARCASM: just one of his many talents.''
l took a old points distributer and stripped the top of the shaft where all the stuff mounts on and ground 2 flat spots at the top of the shaft. then put a C-clip on the shaft so it won't slip out the bottom.
to use: remove stock distributer & put in the primer one. if you want, put a oil gauge in the back of the block to monitor pressure, then attach a 1/2 inch drill, tighten on the shaft then spin the oil pump to prime the motor. l also turn the crank over by hand to get oil all over in the passages. l turn the pump till oil come out the push rods.
Later
Later
