streetrodman
A friend would like me to paint some flames on his charger. It is currently base/clear coat. I was planning on wet sanding the doghouse with 400 grit to scuff the current clear coat. Is this paper too coarse? I want to make sure the next paint (for the flames) will stick well. I will tape off the flames and then I plan on wet sanding with finer paper, (2000 grit) to blend any edges and re-clearing. Any good paint guys got any suggestions?
Thanks,
Streetrodman
Thanks,
Streetrodman
