Boltbreaker
Is there a way to know if a 9" rearens is posi or not by looking at it? Is there any tell tail signs without me opening it up?
Thanks,
Brian
Thanks,
Brian
Thanks Preacher. I will give that a try.if you're lucky enuf to get one with the tag on it, the ratio will have the letters LS, or L between the numbers-such as 3:L50 or 3:LS50 (3:50 ratio)
if i remember correctly..... i've been around a few ford 9" rears..most are open
i want to say if there's no tag, that you can spin the left wheel, while holding the pinion yoke solid, and if the right wheel spins in opposite direction it is open-if spins in same direction means posi/limited slip
if anyone knows more, feel free to correct me-i HAVE been wrong before
I spun one side with my foot and leaned over to the opposite side and the wheel didnt move nor did the hub/studs.Spin one side without holding the pinion yoke and see what the other side does.
