t-bucket
thought some one might have some insight on this
we have a 336 chev v-8. 1958 circa and the rear main is leaking
this is a two piece rope seal. can it be changed without removing the crank?
and without wrecking the front seal? I've heard that you may be able to loosen off the main bearing caps and get the block side out and new one in.
Another question can this be done with the transmission, clutch and flywheel still hooked up??
thanks for helping out
Stuart
Stuart
