I'm in the process of installing a fresher motor in my car but plan on using the old heads on the newer stock block motor. I bought ported and polished heads off a drag motor with about 100 runs on them and used on my old motor and now plan on using on the newer stock block motor. I will be taking the heads to a machine shop and have them gone through but my concern is, while taking the valve covers off the heads, I found that the first three rockers on both heads had rust build up towards the push rod tips and half way back towards the main body. I'm assuming the rust is from condensation from them sitting on the old motor in an enclosed garage for the past 4-5 months. No blown head gaskets, rust or water was found in any of the cylinders, heads or engine oil. The rust was easily removed with the aid of a wire wheel on a bench grinder. I did discover minor surface pitting on these rockers afterward. Should I replace the rockers which I bought new when I first placed the heads on the old motor, Approximately 15,000 miles ago (rockers are stock type rockers with roller tip) or should I not worry about the minor pitting and reuse them. Any and all answers will be appreciated
