s10 steering column
dad6timz
Sep 17, 2012
8
I'm putting a 46 chevy truck on a s10. The cab and fenders are in place. I went to put the steering column in and it's not long enough. I'm using all s10 parts. I need advice on what to do. Can I lengthen the s10 column some how or do I need to get another column? Any and all advice is greatly appreciated.
photos of steering column and photo showing how the wheels are in the center of the fenders
I suggest you ditch the late model s10 wheel and column and replace it with something simple. Find a a tube column from a old car or truck, or even a newer (pre-90's) large vehicle, like a bus or delivery van.
But to answer your question, you'll probably need to get an extra knuckle and shaft - go pull them out of most any GM of around the same year. Don't weld a steering shaft - just not a good idea.
This is my Olds column on a 85 Cutlass frame.
attachment.php
attachment.php
If you decide on making your own [;) P/M me,I have a link to another site that show how to make your own column-Chuck
Go to the junkyard and get a longer steering sector (the colapsable piece that goes between the column and the steering box). Look at 70's full size cars, trucks, camaros ....etc.
I also like the idea of adapting an old column. I used the 48 column when I did my S-10 swap (plus a 79 camaro steering sector).
