comparing the 305, 307, 327, and 350, The 305 is a good engine if you dont plan on trying to build ground pounder. My last S10 had the TPI 305 in it and it out ran many larger displacement engines. However, you have to remember, it is small journaled and are limited on what you can produce without spending a lot of $$$. Strangely enough, I ran a hi-po 350 cam in mine and it was excellant. The 305 will like less carburation such as a 600cfm (originally designed around the sbc). The 307 and 327 (small journal) will be the same as your 305 as far as building. The 327 will be a little more forgiving when building though. If you plan on building a ground pounder, look around for a 350. You will spend less money and end up with better results. Pound for pound, the amount of money you'll spend stroking a small journaled engine, you can spend less money building a 383 (for there are tons of these kits out there now) and have more bang for your buck. Of course, you may get lucky and find a 400 but the 350s are still plentiful in the salvage yards and still for a decent price (for your planning on building it anyways).
