oldracer22
I have used two different lower alternator mounts. They have both broken the lower bolt to the block. I assume this is because it is in single shear. I just discovered this, and it is a pain to repair. The bolt is broken off flush with the block. I have to remove the radiator to make room for a drill and easy out. Has anybody else had this problem? Know of any fixes so it doesn't happen again?
