My dad has an 89 F150. The other day he calls and says the truck wont start. The key turns to accessory just fine but when you turn to start, the key just flops over, no resistance, no start. But if I turn the key to the start position and cross the terminals on the solenoid, it starts right up.
I figured it was the ign. cylinder, so I replaced it. Not the problem, did the same thing as the original one. So I pulled out the ign. switch from the top of the column and replaced it. Again, not the problem, same thing happens. The linkage rod between the cylinder and the switch moves just fine when you turn the key.
So in the interest of temporarily fixing it enough for dad to drive it, I just was going to wire a bump switch to jump the poles on the solenoid. I wired in a 15A switch with 10g wire, and..... nothing happens except for the wire getting hot. What the hell, it'll start using a screwdriver across the solenoid, but not a switch?
I know Im probably overlooking a simple fix here, but a little help would be appreciated.
Thanks, Hodag
Thanks, Hodag
