deluxerux
Ok so I have a 69 Camero 10 bolt rear end and I have 35 ford wire wheels. Can someone help me figure out what kind of spindles I need for my Model A? I also have the 4" drop A straight axle up front.
Thanks.
Thanks.
When looking for front hubs, be sure to get the ones with the brake drum on the inside of the flange. The ones with the drums on the outside won't accept the wires. My '39 hubs are wrong,I have to swap some '48's on.
Rally America sells an adapter so you can run 35 wires on a newer rear end, like a 10 bolt, 9 inch, etc. They have various bolt patterns and they properly locate the wheels on the drums.
$60.00 Each
Kelsey Hayes Spacer/Adapters
Used to put '28-'35 Ford Wire Wheels and Kelsey Hayes Wire Wheels on newer brake setups.
This '33 coupe has '40 drums and '35 wires and has been driven thousands of miles all over the country. Pretty solid "real world" experience...
