kelseydum
I've got a switch panel I made out of stainless steel... pretty simple set up. In my wiring kit I have a wire for the horn (1 switch), hazzard flasher (1 switch), cell phone charger/ cig lighter (1 switch), and 1 accessory wire.
The wires mentioned above are spoken for except the accessory wire. I want to have a switch for my (4) cab lights on top, a switch for my dome light, and a switch for my interior neon I'm going to put under the dash.
I can hook up a normal white dome light to my headlight switch so that shouldn't be a problem, but how do I wire two separate accessories off of one wire? Will the switches do the thinking or do I need to install some sort of relay? Do I need any extra fuses?
The lines marked "(wire)" in my awesome diagram are coming from the fuse box.
