todays metal project
cornfield customs
Mar 16, 2008
1,027
Loveland OH
decided to make a new lower cowl replacement panel for the passenger side.since the new sedan i got had new panels to use as a template. one on the left is my panel one on the right is one that came on my car
Looks great. Did you hammerform the rounded lip over a wood form and then shrink it?
What shrinker stretcher do you have?
no i didnt hammer form it, i used my bead roller with a tipping die and rubber lower die. then stretched the upper flange to give it the convex curve.
i have an old shrinker/ stretcher name unknown, and a cheapo set from hf
say what
Once again the corn man puts out some cool panels.[cl
Is your die serrated to make the interesting pattern to the beads on that panel??
have fun
Tom
no again it is just a standard tipping die up top and rubber wheel on the bottom. the rubber wheel allows you cross lines with out messing up the original
Sorry maybe I asked the wrong question[S
I understand the rubber die bottom. It is the rope pattern the die make not the diamond pattern with lines crossing each other.
have fun
tom
made this box to cover up the air management system in a customers truck, still need to make the louvered notch cover and louver the sun visor. here is what i have got so far
Nice work , i'm thinking it would make a great looking tool box for my 64 , but i guess it would not be very water tight ::D
frenchy,
i could roll that out on any material and in any size grid pattern to suite your needs. just let me know the details and i can get you a quote.
scuba,
the box can be made more water tight if you are interested in one, i could weld a panel under the louvers, or use weld bond adhesive and put a piece of aluminum under it to keep it from rusting. i can make it any size and design. louvers or some designs rolled into it, ie. flames, tool outlines, or a logo.
