WIZEGUY
Our resident wisecat
Here is a simple tip for anyone who has gotten tranny fluid spilled all over them. If you don't have a drain plug on your pan, you can do this.
Take all the bolts, except for four on the front corner area of the pan, out.
With drain pan in place, simply loosen the remaining four a little at a time.
The fluid will gradually drain into your pan as you go back and forth loosening the bolts.
If you use one hand and support the pan slightly, you will not bend or damage the edges.
Tracy
Tracy
