You might try the old school method. I'm assuming it's now rust free? If it is, wipe it down with the old metal prep. It's green stuff in a gallon jug. Get a heavy fill lacquer primer, it fills lots of sanding marks, put a couple of coats on. Then lightly water sand with a 400 grit wet/dry sand paper. Blow off with an air hose. Make sure you have a good water trap on your air compressor. Wipe down lightly with a rag with Lacquer thinner. Then use a tack cloth. Now, Shoot the whole thing with a coat of lacquer. This will do 2 things to help you in further body work on the car. You can see dents, scratches ect. It also seals the primer so it doesn't suck up moisture. It doesn't matter what color lacquer you use, as long as it isn't the same color as the primer. Learn how to use body hammers, picks, dollys body files and slap files. If you have to fill over an 1/8", you need to do more hammer work. If you have to grind a spot to bare metal again, use a propane torch to flash off moisture on the metal. Flashing means just wave the flame quickly over the metal. You will actually see the moisture run before the flame. Think about this: Moisture under anything will never go away, just turn back into rust and you get to do it all over again. Some people swear by a non sanding sealer primer. I swear at it. I could write a book on some of this old school body and paint.
