how many wires do i run to my tail lights i'm using 32 ford so they each have 2 wires,, 1 ground 1 hot. so how many do i need to run from the fuse block
Hey skyrush...the two wires are for tail lite and brake lite. Grounds thru the tail light housing when you mount it with bolts to the body. One wire from fuse block to the headlite switch. Then a wire from headlite switch taillite connection to the taillite. Then a wire from fuse block to your brake lite switch, usually at the barke pedal then from there to the other wire on the taillite . The dim lite is the taillite and the brite one is the brake lite. Have fun!!
