Yours might be a rat rod................................
more
QUOTE]
you have lost change, tools and large objects thru the rust holes in the floorboards
flow thru ventalatioin are holes in the firewall
your'e heater is the holes in the firewall[dr
your'e guages cost more than the whole car is worth
you have all the parts stores places phone numbers memorized but not the wifes cell phone
It might be a rat rod if: You keep getting "Code Violation" warnings from the city telling you - "You have 30 days to remove the abandoned vehicle from your property or you will be summoned to appear in court."
This actually happened to me last week after two and a half years of storing my cab behind my house!!! Good thing I'm moving by Nov. 1st!
you bring your project home and the old lady ups the life insurance..........
while cruising the new car lot they wanted to charge you to take it.......
the manager of walmart asks that you remove it from the lot so as not to disturb the other shoppers.........
the mill machine goes down on the road and they ask if you could make a couple passes to finish up the lane...........
krylon sends you christmas cards and rustoleum sends birthday wishes every year.....
if you have ever had to ask the passenger to pass the window crank.....
you use vice grips as a shifter
you use vice grips as window cranks and door handles
you have a 4 speed tranny and you shift 1st- 2nd gear with coloulm shifter and 3rd-4th gear and reverse with floor shifter:confused:
mite be if
you use small blocks chevys as night stands.
a healthy lunch is a peanut butter and grease sandwich
the gets coffee is cold, you warm it up with the torch.
use a scrap piece flat steel and a torch to cook a grilled cheese sandwich(did that)
you have $20,000 in tools to keep a $2,500 car running:D
you can tell the weight and brand of oil by taste
you can run a plasma cutter, welder, and a cutting torch but not the kitchen stove.
you do the christmas shopping at a swap meet.
You use the same pan you drain your oil in to cook you hotdogs.
Seen that done.
You use auto parts a christmas ornaments on your tree.
If small children cry when you start your car....
If old people walk a little faster to pass your car in a parking lot....
so many of these "you might own a rat rod" have happened to me.
These are all really good [cl
you might be A rat rodder if:
you have more hotwheels and die cast cars than every kid on the block[dr
(pics of my den)
the smell of nitro has the same effect as viagra.
you have ruined more than one washing machine by not removing tools or nuts and bolts out of you're pants.
you only visit you're friends in reno so you have place to stay during hot august nights
"you have ruined more than one washing machine by not removing tools or nuts and bolts out of you're pants."
OOOOOOOOH! I'm guilty of this one twice.:D:D........CR
Been There myself
